Home
Products
Purchase
Downloads
Partner
About Us
Download
Buy
Upgrades
Visual Reference Guide - Animation
The reference guide shows visually how different parameters settings will affect your project. This guide is also useful in highlighting the flexibility of the Effect3D Studio application
Standard Animation
Using the most advanced animation technology, FFD (Free-Form Deformation) and RTS (Rotate, Transform & Scale) Effect3D Studio can make 3D objects move back-and-forth, float, rotate, bow, dance, or even do the hula-hula!
Animation Strength
Animation strength can be used to alter how strong or exaggerated the animation will appear
Strength 30
Strength 60 Strength 100
Animation Tempo
Animation Tempo can work with all types of animation's in Effect3D Studio. Through the result of tempo adjustment may be varied (obvious or not) according to the original tempo of animation's.
Smooth
Ease-in (slow to fast)
Ease-out (fast to slow)
Text
Animation
Standard
Animation
Standard
Animation
Custom
Animation
Animation Duration
  Animation Duration is determined by frame no. & frame rate:
Animation length (Duration, sec.) = Frame No./Frame Rate
Note: More frames create a larger animation file, while a higher frame rate makes the animation smoother.
Frame No. = 20
Frame Rate = 5
Duration = 4 sec.
File Size = 49 k
Frame No. = 20
Frame Rate = 10
Duration = 2 sec.
File Size = 49 k
Frame No. = 20
Frame Rate = 15
Duration = 1.33 sec.
File Size = 49 k
Frame No. = 10
Frame Rate = 2.5
Duration = 4 sec.
File Size = 24 k
Frame No. = 10
Frame Rate = 5
Duration = 2 sec.
File Size = 24 k
Frame No. = 10
Frame Rate = 7.5
File Size = 24 k
Frame No. = 5
Frame Rate = 1.25
Duration = 4 sec.
File Size = 12k
Frame No. = 5
Frame Rate = 2.5
Duration = 2 sec.
File Size = 12k
Frame No. = 5
Frame Rate = 3.75
File Size = 12k
<font color="#CCCCCC" face="Arial, Helvetica, sans-serif" size="2"> <p><Effect3D 3D animation software - Finally, a graphics program that's easy to use and produces professional quality animations in just minutes. The latest version of effect 3d from reallusion combines a robust graphic editor with a powerful wizard. You'll be producing stunning 3d effects for animated gifs, web graphics and more with just a few clicks.></p> <a href="http://effect3d.reallusion.com/e3d_gallery.asp"><view our 3d image gallery></a> <a href="http://www.reallusion.com/download.asp"><download free trial of effect 3d animation editor software></a><br> <a href="http://effect3d.reallusion.com/e3d_features.asp"><features of 3D graphic editor></a><br> <a href="http://www.reallusion.com/dzone/dz_gallery1.asp"><visit our designer zone to see how you can use Effect3D with other apps like 3DS></a> <p><Effect3d lets you have fun with photo realistic renderings of 3D objects with effects like a wooden, marble or metallic gold finish. Enjoy powerful artistic rendering effects to make any object look like a water-color, pastel, outline, cartoon, stipple, or charcoal effect at the touch of a button.> </p> </font>
