Home
Products
Purchase
Downloads
Partner
About Us
Download
Buy
Upgrades
Features - Materials/Effects
Artistic styles with NPR effects
Effect3D Studio includes 24 Photo-realistic and Non-Photo realistic rendering style effects, complete with extended effect parameters, this includes: real, wireframe, wooden, golden, cute cartoon, seurat, and many more...
Real styles with PR effects
Once you have selected a rendering style you can adjust the material settings. You can choose a material setting from the large gallery of pre-set material settings provided, or you can define and save your own material settings. When defining your own material setting there are many parameters available for adjustment including: color, diffuse, specular, glossiness, absolute glossiness. You can also adjust the background and objects brightness, contrast, hue & saturation.
Each rendering style comes complete with extended parameter settings
Using Effect3D Studio's advanced features you can add texture and bump maps to your 3D objects providing a professional 3D look. You can even blend color and texture effects together. Applied maps can be adjusted using scale, tiling, and offset parameters. The object transparency setting can be adjusted to make the object look less opaque or you can apply a transparency mask to add different levels of transparency across your 3D object.
Effect3D Studio includes an Anti-aliasing option for smoother images this removes the sharp jagged edges from the image file when exported. You can also save material/effect parameters in projects so you can re-use your creativity time and time again.
| General | 3D Objects | 3D Text | Material | Animation |
| Lighting | Export | Composer | Web | Go to Key feature
More Information - Additional Rendering Examples
More Information - Additional Material Examples
More Information - Additional Processing Examples
<font color="#CCCCCC" face="Arial, Helvetica, sans-serif" size="2"> <p><Effect3D 3D animation software - Finally, a graphics program that's easy to use and produces professional quality animations in just minutes. The latest version of effect 3d from reallusion combines a robust graphic editor with a powerful wizard. You'll be producing stunning 3d effects for animated gifs, web graphics and more with just a few clicks.></p> <a href="http://effect3d.reallusion.com/e3d_gallery.asp"><view our 3d image gallery></a> <a href="http://www.reallusion.com/download.asp"><download free trial of effect 3d animation editor software></a><br> <a href="http://effect3d.reallusion.com/e3d_features.asp"><features of 3D graphic editor></a><br> <a href="http://www.reallusion.com/dzone/dz_gallery1.asp"><visit our designer zone to see how you can use Effect3D with other apps like 3DS></a> <p><Effect3d lets you have fun with photo realistic renderings of 3D objects with effects like a wooden, marble or metallic gold finish. Enjoy powerful artistic rendering effects to make any object look like a water-color, pastel, outline, cartoon, stipple, or charcoal effect at the touch of a button.> </p> </font>
